gearSKIVING 2.0
gearSKIVING 2.0
  • Straight and helical external or internal spur gears and splines
  • Arrow teeth with tooth offset Turn-mill machines
  • Ball-shaped toothing by mathematical transformation of the 6th virtual axis
  • Internal toothing without angular head possible
  • Short processing times, 10 x faster than shaping
  • Synchronization and tool path controlled by the Cycle
Left : Inside gear profile machining. / Right : Outside gear profile machining.
Videos
Process Integration in Gear Machining: Production of a Spiral Bevel Gear on the INH 63
Complete machining of gear parts with technology cycles on NTX 2500
DMG MORI gearSKIVING 2.0
Technical data
Machines
CTX
NLX*
NZX (Tailstock)
CTX TC
CTX TC 4A
NTX
NZX
CTV**
DMU eVo
DMF
DMU / DMC duoBLOCK**
Controls
CELOS with SIEMENS
CELOS with MAPPS
● available
